IHI turbos nfo
Тюнинг и доводка автомобилей
IHI turbos nfo
Сообщение ATOMIC » Чт фев 21, 2008 00:08
IHI Turbos
VF22
This turbo has the highest output potential of all of the IHI VF series turbos and is the best choice for those who are looking for loads of top end power. The top end power however, does not come without a cost. The VF22 spools significantly slower than the rest of the IHI models due to the larger P20 exhaust housing and is much less suited for daily driving than some of the other models. Although the largest VF series turbo, the VF22 is not quite optimal for stroked engines or those who wish to run more than 20PSI of boost.
VF23
This turbo is considered a great all-around turbo. Like the VF22 it utilizes the largest P20 exhaust housing. This housing is mated with a smaller compressor housing of the of the VF24. This turbo is considered optimal in applications with range from mild to slightly wild. It does not have the same top end power of the VF22, but spools up significantly quicker.
VF24
This turbo shares its compressor housing with the VF23 however, this housing is mated with a smaller (P18) exhaust side. The smaller characteristics of this turbo allow it to provide ample bottom end power and quick spool. This turbo is very popular for Imprezas with automatic transmissions and Group N rally cars.
VF28
This turbo came standard on the STi Version 5. In terms of overall size, it is smaller than the VF22, VF30 and VF34, and about same size as the VF23.
VF29
This Turbo is nearly identical to the VF24, with the same compressor and exhaust housings. However the compressor wheel in the VF29 is has been changed slightly. The changes made to the compressor wheel in this model are generally viewed as improvements, and as such this unit is typically chosen over the VF24.
VF30
The VF30 is commonly considered the best bang for the buck turbo in the IHI VF series line. A relatively new model the VF30 features the same exhaust housing as the VF24 but a larger compressor side similar to the VF22. The combination of these two parts results in increased output potential without the lag associated with the VF22. Although it doesn't offer the top end supremacy of the VF22, the VF30 is a great compromise between these unit and the quicker spooling models.
VF34
The VF34 is nearly identical to the VF30, with the same exhaust housing and compressor. However the VF34 goes back to the ball bearing design, and in doing so achieves full boost approximately 500RPM sooner than the comparable VF30. The VF34 is the most recent IHI design and as such costs slightly more than its counterpart. Top end performance and maximum output are identical to the 30.
VF35
VF35 The VF35 has identical internals as the VF30 and it uses divided thrust bearings. However, the exhaust housing is a P15 which means this turbo will have fantastic spool characteristics. This turbo is standard on the new WRX Type RA. LIMITED SUPPLY.
VF36
Roller bearing version of the twin scroll VF37, also has a titanium turbine and shaft for even quicker spool. Same compressor housing as VF30/34, however twin scroll P25 exhaust housing provides slightly better top end output due to reduced exhaust pulse interference. This turbo is good for 400HP and used on JDM STI Spec C from 2003 onwards.
VF37 (thrust bearing)
Enter the age of twin scroll IHI turbos. Same compressor housing as VF30/34, however has a new twin scroll P25 exhaust housing that provides slightly better top end output due to reduced exhaust pulse interference. Twin scroll also provides better spool up for improved low down response over the VF30/34. This turbo is good for 400HP and used on JDM STI from 2003 onwards.
VF38
Twin scroll turbo with titanium turbine and shaft. Smaller compressor housing than VF36/VF37 provides tremendous spool up capabilities but less top end than VF36/37. The spool capabilities of this turbo are demonstrated on the JDM Legacy GT, which reaches peak torque at 2400RPM.
VF39
Single scroll turbo used on USDM STI and latest 2.5L STIs released internationally. Smaller than VF30/VF34.
VF42
Exclusive turbo to the S203/S204 models, this features a twin scroll design with a slightly larger compressor than the VF36/37 turbos and different turbine design (more blades). The VF42 is a roller-bearing turbo and is likely of similar size to the VF22 turbo, but with twin scroll exhaust housing for faster spool and superior top end performance due to reduced exhaust pulse interference.
_________________
+38-050-330-52-08
ECU tuning:
RACEROM, ECUTEK, HKS F-CON,
MOTEC, LINK ECU,COBB
ATOMIC
Сообщение PashaWRX » Сб сен 13, 2008 13:14
а про VF 43 есть что-то?
STG_Motorsport 050-430-24-99
STI 06
STI 04 drift spec
BRZ 13
PashaWRX
Сообщение Ivan_08wrx » Сб фев 21, 2009 01:29
а нет инфы про VF 52 ?!
Ivan_08wrx
Сообщение ATOMIC » Сб фев 21, 2009 10:09
vf35=vf39=vf43 vf48 имеет чуть лучший горячий хаузинг и меньшее бэкпрешер
+38-050-330-52-08
ECU tuning:
ATOMIC
Сообщение ®@©E® » Вс фев 22, 2009 12:32
ATOMIC писал(а):vf35=vf39=vf43 vf48 имеет чуть лучший горячий хаузинг и меньшее бэкпрешер
не сходиццо :roll: у vf35 Р15, у інших Р18, краще сказати
vf34 =~ 39 = 43, але тільки по розмірах.
так, ну і щоб всім було цікаво:
ці позначення - специфічні для IHI розміри турбінного хаузінга (A/R = area/radius. величина непогано характеризує спул/здування турбіни (чим більша цифра тим гірше спулить і відповідно менше здувається). специфічність - в тому що IHI все міряє в міліметрах - A/R = mm2/mm. інші виробники переважно в дюймах, або просто пишуть площі і радіуси. гарет наприклад в дюймах. взявши турбу з Р18 і поділивши 18 на 25.4 отримаєм щось типу A/R .70. це якщо раптом захочеться порівняти турбіни різних виробників
®@©E®
Сообщение elinas » Ср апр 01, 2009 08:55
Какая пара турбин производительней?
Все турбины -IHI
1. VF13
VF14
2. VF25
VF27
3. VF31
VF32
и отдельно про турбину VF33, какую турбину можно использовать с VF33(если это первая соответственно)?
®@©E®., Ви писали: -"(чим більша цифра тим гірше спулить і відповідно менше здувається)", можна трошки розжувати? :oops:
elinas
Сообщение ®@©E® » Ср апр 01, 2009 11:40
elinas, це про цифру після буковки "Р" - Р15, Р18... Турбо з хаузінгом Р15 раніше вийде на надув ніж Р18, але і раніше почне лімітувати потік у вихлопі, тому Р18 при інших рівних дасть більше потужності, ніж Р15.
А от про бі-турбо практично нічого не знаю.
®@©E®
Re: IHI turbos nfo
Сообщение DDD-Race » Пт окт 16, 2009 02:16
ATOMIC писал(а):VF42
Exclusive turbo to the S203/S204 .........
интересная весчь.....ты не пробовал ее в работе?
DDD-Race
Алкотреш Тим
Сообщение ATOMIC » Вт окт 20, 2009 23:48
хм....а то тыы не знаешь)) нет только на фото облизывал
размеры те же чуть лучше компрессор, титановый вал с другим углом атаки лопостей, и ценник как цельного куска золота такого же веса
+38-050-330-52-08
ECU tuning:
ATOMIC
Сообщение DDD-Race » Вт окт 20, 2009 23:50
ATOMIC писал(а):хм....а то тыы не знаешь)) нет только на фото облизывал
вот пи...ры японские - всё лучшее у них, как обычно, детям.....
DDD-Race
Алкотреш Тим
Сообщение Shylight » Ср окт 21, 2009 09:55
А по VF36 кто может что-то сказать?
Я имею в виду практический опыт эксплуатации, а не теорию.
Shylight
Pussy lover
Сообщение DDD-Race » Ср окт 21, 2009 10:47
Shylight писал(а):А по VF36 кто может что-то сказать?
Имею большой практический опыт по VF36, НО на машинах Gr. N с рестриктором - поэтому не могу сказать, что там происходит на высоких оборотах. Но снизу подхват очень хороший, очень быстрый спул, пик наддува на 3100-3200 (1,7 - 1,9 бара). Как и для большинства подшипниковых основная проблема - ресурс. Хотя, если я не ошибаюсь, то Валера КАТ до сих пор на стоковой турбине катается на нашей бывшей тренировочной Spec C....... а может у него уже там на втулки переведенная, не помню......Вот кстати из плюсов - Ростик на турбосервисе имеет большой опыт по ремонту этих турбин и переводу их на втулки собственной разработки, работает отлично.
Как по мне, то это очень хороший вариант для умеренного твин-скролл апгрэйда двухлитрового мотора......цена только кусается.
DDD-Race
Алкотреш Тим
Сообщение Lambert » Ср окт 21, 2009 12:17
DDD-Race писал(а):ñíèçó ïîäõâàò î÷åíü õîðîøèé, î÷åíü áûñòðûé ñïóë, ïèê íàääóâà íà 3100-3200
èíòåðåñíî, à íàñêîëüêî öåëåñîîáðàçíî ìíå âîòêíóòü òàêîå íà ñòàðûé 1.8 ìîòîð?
ðîäíàÿ òóðáà óìèðàåò, à õîòåëîñü áû êàê ðàç êàê ìîæíî áîëåå ðàííåãî ïîäõâàòà
Lambert
Сообщение Andr3y » Ср окт 21, 2009 12:20
Andr3y
Сообщение Shylight » Ср окт 21, 2009 14:25
DDD-Race
Спасибо за развернутый ответ! :beer:
Я правда прицелился на Power Enterprise 1825f но она основана на VF36 так что думаю будет в самый раз.
Shylight
Pussy lover
Вернуться в Тюнинг
