Загорелся Chek и Круиз! Какие варианты?
Сообщение mad-max » Пт авг 05, 2011 12:13
mad-max
Сообщение Legacy :D » Пт авг 05, 2011 12:19
Я должен угадать, какая машина, какого года и номер ошибки?
Ну тогда, наверное что-то из этого:
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
P1087 Tumble generator valve #2 (LH) position sensor circuit high input
P1088 Tumble generator valve #1 (RH) position sensor circuit low input
P1089 Tumble generator valve #1 (RH) position sensor circuit high input
P1090 Tumble generator valve #1 (RH) malfunction (stuck open)
P1091 Tumble generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator valve #2 (LH) malfunction (stuck open)
P1093 Tumble generator valve #2 (LH) malfunction (stuck close)
P1094 Tumble generator valve circuit #1 (open circuit)
P1095 Tumble generator valve circuit #1 (over current)
P1096 Tumble generator valve circuit #2 (open circuit)
P1097 Tumble generator valve circuit #2 (over current)
P1100 Starter Switch Circuit Malfunction
P1101 Neutral Position Switch Circuit High Input (A/T)
P1101 Neutral Position Switch Circuit Malfunction (M/T)
P1102 Pressure Sources Solenoid Valve Circuit Malfunction
P1103 Pressure Sources Switching Solenoid Valve Circuit
P1104 Engine Torque Control Signal Circuit Malfunction
P1106 Engine Torque Control Signal 2 Circuit Malfunction
P1110 Atmospheric pressure sensor low input
P1111 Atmospheric pressure sensor high input
P1112 Atmospheric pressure sensor range/performance problem
P1115 Engine Torque Control Cut Signal Circuit High Input
P1116 Engine Torque Control Cut Signal Circuit Low Input
P1120 Starter Switch High Input
P1121 Neutral Position Switch Circuit High Input [MT Vehicles]
P1121 Neutral Position Switch Circuit Low Input [AT Vehicles]
P1122 Pressure Sources Switching Valve Circuit High Input
P1124 TCS Signal Circuit High Input
P1130 Front oxygen sensor circuit malfunction (open circuit)
P1131 Front oxygen sensor circuit malfunction (short circuit)
P1134 Front oxygen (A/F) sensor microcomputer problem
P1137 Front oxygen (A/F) sensor circuit range/performance problem
P1139 Front oxygen (A/F) sensor #1 heater circuit performance/range problem
P1141 Mass Air Flow Sensor Circuit High Input
P1142 Mass Air Flow Sensor Circuit Low Input
P1143 Pressure Sensor Circuit Low Input
P1144 Pressure Sensor Circuit High Input
P1146 Pressure sensor circuit range/performance problem (high input)
P1150 Front Oxygen Sensor Heater Circuit High Input
P1151 Rear Oxygen Sensor Heater Circuit High Input
P1230 Fuel pump control unit malfunction
P1244 Wastegate control solenoid valve malfunction (low input)
P1245 Wastegate control solenoid valve malfunction (fail-safe)
P1301 Fire due to increased exhaust temperature
P1312 Exhaust temperature sensor malfunction
P1325 Knock Sensor Circuit Low Input
P1400 Fuel Tank Pressure Control Solenoid Low Input
P1420 Fuel Tank Pressure Control Solenoid High Input
P1421 Exhaust Gas Recirculation Circuit High Input
P1422 EVAP Purge Control Valve Circuit High Input
P1423 EVAP Vent Control High Input
P1440 Fuel Tank Pressure Control System Low Input
P1441 Fuel Tank Pressure Control System High Input
P1442 Fuel Level Sensor Circuit Range/Perf
P1443 EVAP Control System Vent Control Function Problem
P1480 Cooling fan relay 1 circuit high input
P1500 Radiator Fan Relay 1 Circuit Malfunction
P1501 Idle Control System Malfunction (Fail Safe)
P1502 Radiator Fan Function Problem
P1507 Idle Control System Malfunction (Fail Safe)
P1510 Idle Air Control Solenoid Signal 1 Circuit Low Input
P1511 Idle Air Control Solenoid Signal 1 Circuit High Input
P1512 Idle Air Control Solenoid Signal 2 Circuit Low Input
P1513 Idle Air Control Solenoid Signal 2 Circuit High Input
P1514 Idle Air Control Solenoid Signal 3 Circuit Low Input
P1515 Idle Air Control Solenoid Signal 3 Circuit High Input
P1516 Idle Air Control Solenoid Signal 4 Circuit Low Input
P1517 Idle Air Control Solenoid Signal 4 Circuit High Input
P1518 Starter switch circuit low input
P1520 Radiator Fan Relay 1 Circuit High Input
P1540 Vehicle Speed Sensor Malfunction 2
P1544 High exhaust temperature detected
P1560 Back-Up Voltage Circuit Malfunction
P1590 Neutral position switch circuit high input
P1591 Neutral position switch circuit low input
P1592 Neutral position switch circuit (MT model)
P1594 Automatic transmission diagnosis input signal circuit malfunction
P1595 Automatic transmission diagnosis input signal circuit low input
P1596 Automatic transmission diagnosis input signal circuit high input
P1698 Engine torque control cut signal circuit low input
P1699 Engine torque control cut signal circuit high input
P1700 Throttle Position Sensor Circuit Malfunction (A/T)
P1701 Cruise Control Set Signal Circuit Malfunction (A/T)
P1702 Auto Trans Diagnosis Input Signal Circuit
P1703 Low clutch timing control solenoid valve circuit malfunction
P1704 2-4 Brake Timing Solenoid Valve Circuit Malfunction
P1705 2-4 Brake Pressure Solenoid Valve (Solenoid D) Circuit
P1711 Engine torque control signal 1 circuit malfunction
P1712 Engine torque control signal 2 circuit malfunction
P1722 Auto Trans Diagnosis Input Signal High Input
P1742 Auto Trans Diagnosis Input Signal Malfunction
Legacy :D
Outback, 2.5, 2005г.
Сообщение mad-max » Пт авг 05, 2011 12:35
mad-max
Сообщение Legacy :D » Пт авг 05, 2011 12:40
mad-max
Читай ошибку, потому будем думать, что делать.
Legacy :D
Сообщение Sergey_od » Пт авг 05, 2011 13:01
С этим ником отловился - подумал как это Мэд Макс не знает что с ошибкой делать ))) :D
LEGACY 2.0 GT
Sergey_od
Сообщение @ps » Пн авг 15, 2011 14:08
Чек и круиз у меня из-за лямбда-зонда загорелся. Качественный бензин, едрить его, хотя и заправляюсь на ОККО.
Если это лямбда, можно просто обнулить, но ошибка будет опять возникать в дальнейшем. Мне на вазза-сто поставили на новую лямбду механическую обманку, проблема исчезла.
@ps
Re: Загорелся Chek и Круиз! Какие варианты?
Сообщение navigator_a » Вс фев 24, 2013 18:34
Доброго всем времени суток! Первый раз пишу, возможно не там где нужно (заранее пардон. У меня Аут 2008, та же фигня (Чек и круиз) и как ни странно после ОККО. Ошибку сняли на сервисе, посоветовали промыть инжектор, почистить свечи. Старый хозяин этого не делал ни разу (пробег 88000 км) Все сделал как советовали, ехать конечно стала интересней, но средний расход был 9,5 а теперь 8,5 км/л... Как то не очень прикольно. Езжу аккуратно не резво. Может что-то посоветуете?
navigator_a
Сообщение maximc » Сб июн 01, 2013 17:28
Подскажите пожалуйста после диагностики вылезло
C0109
P2504
(Тоже после езды на круизе)
Помогает ли снятие минусовой клеммы для обнуления ошибок
Спасибо
Авто OUTBACK 2.5 2005 4AT
>>>>Снятие клеммы не помогает. Но на следующее утро, подумав что если это из за не сгоревшего "Г" дал машине "просраться" , и Чек и Круиз погасли :D Что за дела.....?
Жизнь - это бесконечное совершенствование. Считать себя совершенным - значит убить себя.
OBK 2.5AT 2006
+38(050)543-5787, +38(093) 429 8949
maximc
Сообщение alex_xel » Пн июн 03, 2013 12:30
maximc
Из того что нашел...
Р2504 Charging system - voltage high (Wiring, alternator, battery)
С0109 – ABS Control module Supply Voltage Malfunction
Probable Cause[s]
Open or short circuit condition
Faulty Battery
Faulty Generator
Faulty Relay
Faulty ABS Control Unit
Короче чето с напругой...
Сообщение maximc » Пн июн 03, 2013 20:42
alex_xel писал(а):maximc
Р2504 Charging system - voltage high (Wiring, alternator, battery) >>> С этим разобрался - эта ошибка осталась у меня так как АКБ разряжался
С0109 – ABS Control module Supply Voltage Malfunction >>>>> Вот с этим не совсем понятно :shock:
Probable Cause[s]
Faulty Battery
Faulty Generator
Faulty Relay
OBK 2.5AT 2006
maximc
Сообщение alex_xel » Пн июн 03, 2013 22:18
maximc
Ну дык а че непонятно то? две ошибки, и обе с напряжением... Если причина одной извесна, то скорее всего это же и причина второй. Написано же - Faulty Battery.
В современных автомобилях электронные системы идут в комплексе, и если где-то сбой то одно тянет за собой другое.
Сообщение maximc » Вт июн 04, 2013 07:17
>>> спасибо за разъяснения, также мне писали что С0106 - это ошибка ламда-зонда, вот поэтому и не понятно %)
OBK 2.5AT 2006
maximc
Сообщение alex_xel » Вт июн 04, 2013 08:07
maximc
Ну дык тут как бы определится надо... С0106 или С0109...
Мало того ошибки начинающиеся на С.... , Это ошибки АБС, и все что с ней связано... и С0106 в данном случае это датчик скорости левого заднего колеса.
Сообщение maximc » Вт июн 04, 2013 17:43
C0109 Была ошибка, извините что ввожу в заблуждение
OBK 2.5AT 2006
maximc
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 106
